Author Topic: in the morning cold starting  (Read 1524 times)
Offline forsh
« on: 05 September 2010, 08:31 »
i find in the morning sometimes when i try start my vr6 i get the clocks reseting and flashing like theres not enough power
sometimes after work it happens,but not as much as in the morning,when its cold
the battery has one of them lights on it,and it says fully charged
could the battery be messed up,or the starter trying to take more power then thats needed
Offline thebassman
Re: in the morning cold starting
« Reply #1 on: 05 September 2010, 15:59 »
Sounds weird, but have you got any corrosion build up on the battery terminals?
Mine did and I was getting intermitant current.
Offline forsh
« Reply #2 on: 05 September 2010, 16:59 »
not really,but ill give them a clean just incase
Offline forsh
« Reply #3 on: 09 October 2010, 13:04 »
just a update
still starting bad,lights flashing when i start my ar and the clock resets
its draining power from somewhere
i think maybe its the starter
Offline jonnypolish
  • t2871r needed :)
« Reply #4 on: 09 October 2010, 13:45 »
Check the connections to and from the starter,
If the problem still occurs borrow a battery to see if the battery is just reading wrongly?
 MK2 VR y0!
Offline leigh_harty
  • Audi AGU
« Reply #5 on: 09 October 2010, 17:11 »
I had a very similar problem recently, after a new battery was put on it was discovered that the negative terminal wasnt clamping properly, as in it was on there as tight as, but could spin freely.
clocks reset, radio reset, most times id come to start it. and would sometimes act as if the battery was dead. New battery for nothing basicaly.
Leigh
Dont lose your dinosaur!
Offline Khare
  • The bear that khares
« Reply #6 on: 09 October 2010, 19:11 »
Earth problem. Check all engine earth and clean them.
Offline garethcab
« Reply #7 on: 10 October 2010, 10:30 »
My Cab starting doing that, all clocks reset, etc.
Replaced battery, all fine now.
Offline forsh
« Reply #8 on: 10 October 2010, 15:41 »
think ill check the battery tomorrow,i have a spare newer battery at work
thanks guys
keep you imformed
