Author Topic: 1.8t running problems  (Read 3041 times)
Offline heliosmk2
« on: 04 September 2010, 21:22 »
can anbody help with this. my 1.8t when it gets too 2800rpm and i happen to lift off either change gear or just lift off the engine jerks for a second then carries on ok. its doing my head in. so far i ahev changed the maf sensor and fitted a new dump valve the code showing up on vag com is 00544 maximum boost pressure exceeded intermittent
Offline smartie78
Re: 1.8t running problems
« Reply #1 on: 05 September 2010, 19:21 »
[/ possible boost pressure sensor faulty or a vacuum hose damaged.check hoses to pressure sensor. best cheched correctly by vm or someone with vag com]
Offline heliosmk2
« Reply #2 on: 07 September 2010, 21:10 »
all sorted i hope n75 in wrong way doh  :grin:
Offline the40ftpenguin
« Reply #3 on: 11 September 2010, 20:45 »
i have the same problem..mines showing error codes 0220 maximum boost pressure exceeded and 0231 lambda adoption multiplicative too low...so as i understand it my fuel system n turbo r the problem...what did ur turbo end up being?
1.8 20v Turbo
AGU
