Author Topic: VR6 IN GTI  (Read 1437 times)
Offline mk3gti
VR6 IN GTI
« on: 19 January 2005, 13:51 »
hello. does a VR6 engine fit on a gti model, what parts would have to be changed ??? thanks craig
Offline mk3gti
Re: VR6 IN GTI
« Reply #1 on: 19 January 2005, 13:51 »
mk 3 gti BTW
mrwotto
Re: VR6 IN GTI
« Reply #2 on: 19 January 2005, 15:57 »
It should do matey, as VW fitted the VR6 engine to the MK3 so i would say yes
Not sure what parts need changing, but I would start with the engine lol
Paul
Offline jte
Re: VR6 IN GTI
« Reply #3 on: 19 January 2005, 16:16 »
Depends on how much comes with the engine.
The mk3 VR6 gearbox is different to GTIs.
The VR6 clutch is hydraulic rather than cable as found in GTIs.
I guess different manifolds.
VR6 dials would be a good idea, ie 160mph and correct rev counter - redline at just under 7k rpm.
Suspension upgrade is a must
Brake upgrade would be advisable unless you have very late spec gti brakes i.e 288mm front discs.
The VR6 has twin cooling fans and possibly a different radiator (same as GTI 16v though)
VR6 ECU
I'm not sure if you need all of this stuff but it's just some ideas.
A VR6 isn't a way of life, it's just a car.
Offline 16v Matt
Re: VR6 IN GTI
« Reply #4 on: 19 January 2005, 16:20 »
Prob be cheeper to sell your current ride, & buy a puka VR6 to be honest matey :undecided:
Re: VR6 IN GTI
« Reply #5 on: 20 January 2005, 11:35 »
Deffo need the VR6 clocks to go with it, as the rev counter uses a different signal to the std clocks.  I believe on the VR it comes from the ECU rather than the coil IIRC
