Author Topic: no dash lights on mark 1  (Read 1253 times)
Offline golfnutz
  • fu's yer du's
« on: 18 January 2005, 16:22 »
hi got 83 golf gti and  i have no dash lights  when i put my lights on my mfa switches off abd my rev counter stops workin any suggestions
Offline mk1
Re: no dash lights on mark 1
« Reply #1 on: 18 January 2005, 20:59 »
Check the small earth wire (brn/white?) on the rear of the rocker cover.
Steve.
Offline golfnutz
  • fu's yer du's
« Reply #2 on: 18 January 2005, 21:49 »
thanks ill give that a try
Offline hairyarse
« Reply #3 on: 19 January 2005, 12:10 »
If you sort the MFA/Rev counter and still no dash lights, check you are getting 12v at pin 1 of the 14 pin connector that goes to the instrument pod. If you are, then check the bulbs - if these ok then maybe the blue track on the back is knackered?!
