Author Topic: RNS510 C LED camera/emblem problem  (Read 2207 times)
Offline golfgti5
« on: 30 August 2010, 16:05 »
Hello,
i swapped mine RNS510 A-version, wich was working perfect with my camera/emblem, for the new RNS510 C LED version, but now my camera/emblem not come's visual.........
anybody who can help me??  (cameluck??)
i didn't change anything with my vag.com cable....
greetings Ron
GTI Mk7 DSG Candy White, 19" Santiagos, Discover Media, xenon, Executive Package, ACC, PDC, Park Assist, Alarm+......
Offline Snoopy
  • Moderator
  • Geoff.
Re: RNS510 C LED camera/emblem problem
« Reply #1 on: 30 August 2010, 16:10 »
The new one maybe set different, check your vag.com settings
http://www.golfgtiforum.co.uk/index.php?topic=152441.0
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline p3asa
« Reply #2 on: 30 August 2010, 16:57 »
Your car will be set up for the rear camera but as far as I know you will still need to set up your RNS510 to utilize the rear camera via VAG.COM as Snoopy has suggested.
Offline golfgti5
« Reply #3 on: 30 August 2010, 17:01 »
So bassicly every time you install an new RNS510 or other RNS510 you will have to do coding again???
Offline p3asa
« Reply #4 on: 30 August 2010, 17:40 »
You would only do the coding if the new head unit hadn't already been set up for the camera as far as I am aware.
With yours being new (according to your other thread) it has to be coded to accept the camera. At least that is the way I read it.
Offline golfgti5
« Reply #5 on: 30 August 2010, 18:45 »
I did the coding, but the reset did it, thanks guys!!!
