Author Topic: how to fit the rear adjusters in?  (Read 1507 times)
Offline ams_sxi
« on: 30 August 2010, 14:38 »
i could not work out how the rear adjusters go in on the springs in the mk5
i tried putting them in on the bottom of the spring but it looks like they will just slide over the place as there is no groove for them to go in?
anyone got a picture of how they should be fitted?
they are from AP coilovers if it helps
thanks
Offline Adam
Re: how to fit the rear adjusters in?
« Reply #1 on: 31 August 2010, 15:54 »
They just perch on the plate. Make sure you have them the right way up i.e part numbers facing the correct way up. You wouldn't believe how many people seem to mess that up.
Down Hill From Here.
Offline ams_sxi
« Reply #2 on: 01 September 2010, 08:48 »
so what way do they go?
at the top of the spring or at the bottom?
Offline Adam
« Reply #3 on: 01 September 2010, 12:09 »
Sorry mis read the question.
They go on the bottom, then you use the bottom plate to 'camp' the adjustor to the perch. Like this mk4 -
Offline ams_sxi
« Reply #4 on: 02 September 2010, 12:10 »
i don't think the mk5 is like this.
if i put the adjuster in at the bottom, there is no way i would be able to get the c spanner in to adjust it
