Author Topic: Cam belt replacement on a mk1  (Read 983 times)
Offline RyanMac
« on: 28 August 2010, 18:58 »
Broke my cambelt today but luckily only when turning it over slowly but whn I went to look at changing the belt I have noticed it has a kent gs2 camshaft.
I am unsure now as how to do it as I dont know where he marks shoud line up.....
Also how do I check I haven't caused any damage without ripping the head off?
Re: Cam belt replacement on a mk1
« Reply #1 on: 28 August 2010, 21:21 »
Will be timed as standard, fit a new belt then carry out a compression test that will confirm if all ok.
Offline RyanMac
« Reply #2 on: 29 August 2010, 08:46 »
Cheers Wayne.
So just line the marks up as normal and fit the belt. I had thought along those lines but wanted someone else to confirm it.... :smiley:
Now to find the marks...
Offline warnesey333
« Reply #3 on: 29 August 2010, 22:13 »
There tends to be a mark on the inside of the camshaft pulley that lines up with the front of the head.
Or at least there is on mine  :grin:
The other way to tell is to take the rocker cover off and look at the lobes on cylinder 1 (given that you are at TDC with piston 1)
The lobes should both be pointing upwards in a V I think.
