Author Topic: Need to stick stuffs!  (Read 1605 times)
Offline sn0rkle
« on: 26 August 2010, 21:57 »
I am looking at some subtle mods to my new mkv gti, metal foot rest, metal seat leve inserts, euro badge on the front etc.
Question, i want to be able to revert to oem easily, any ideas what i could use to stick this stuff down so i can remove it easily in the future?
Any help appreciated...
Oh, i have also bought a black badge, any idea how i swap them?
Offline Gene Hunt.
Re: Need to stick stuffs!
« Reply #1 on: 27 August 2010, 08:18 »
........i got the ''screw fit'' foot rest but for the seat insert i used '' no more nails'' sticky pads. Been on over a year now & still fine but if needed to remove should just pull up.  :smiley:
Candy White ED35.
Offline musicman87
« Reply #2 on: 30 August 2010, 12:26 »
I took the footrest out and screwed it in. If you buy the one from the fella on this forum, it looks so OEM that it should be there from standard anyway.
Believe it or not, i've stuck the seat lever inserts in with Blu-Tack and they've been there for 2 months now and no sign of moving!
55' Tornado Red 3-Door GTI, Manual, 17" Monza's, Totally original!
Offline sn0rkle
« Reply #3 on: 31 August 2010, 20:59 »
Good call with the blue tack, i like it!
Offline reidtastic
« Reply #4 on: 31 August 2010, 21:41 »
clear silicone for the inlays plenty sticking power and will peel of the plastic when removed with out marking the plastic levers.
