Author Topic: Problems with my drivers door card  (Read 3259 times)
Offline the_stink
  • A3 140 TDI
Re: Problems with my drivers door card
« Reply #10 on: 27 August 2010, 23:47 »
....and before the winter, do step one of this link. http://www.matey-matey.com/leak_prevention.shtml
I used the old membranes as a template and did about three layers on my old Rallye. It stopped the leak though that's for sure.
cheers Gibby defo goign to sort this before it gets worse and so does the weather!!
Offline gibby
« Reply #11 on: 28 August 2010, 00:11 »
No worries dude, you're welcome.
......now officially dubless.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #12 on: 28 August 2010, 02:21 »
Old ones Shrink....
Get some good quality plastic sheeting and make your own & use gaffa tape to hold em in place...
All the clips you can get NEW from VW & its worth the dosh to do it....
For More Info Click To See;
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #13 on: 28 August 2010, 09:57 »
I uses some heavy duty clear plastic from b&q and used silicone sealant. Duct tape didn't work. Also I put a small second piece that fit inside the lower hole in the door to deflect water to the drain holes. This stops any problems with water sitting in the bottom of the outer membrane.  Make sure its a good fit otherwise the window will catch it when operating.
Offline the_stink
  • A3 140 TDI
« Reply #14 on: 28 August 2010, 15:54 »
cheers for all the replies guys
Offline stugtd
« Reply #15 on: 28 August 2010, 17:06 »
hi stink i got the same problem on the wife's driver going to try this
http://www.4130-products.com/step/vapor/index.htm
Offline the_stink
  • A3 140 TDI
« Reply #16 on: 31 August 2010, 11:57 »
ahhh nice, thanks for posting, going to try and do this next weekend if its sunny as well as starting the spray job of my rear bumper  :smiley:
Offline the_stink
  • A3 140 TDI
« Reply #17 on: 01 September 2010, 12:02 »
luckily the door card has dried out now but the bottom is now totally warped and well a bit F****** ill see what i can do to remedy it so it fits back on the door and clips in place!
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #18 on: 02 September 2010, 11:41 »
This is what you want to use instead of gaffa/duct tape!
https://www.sitebox.ltd.uk/product/SAFT_50/selfadhesive-aluminium-foil-tape-50mm-x-45m/
You can really smooth it out and it sticks like sh!t to bedsheets!
Offline Steve_B
« Reply #19 on: 02 September 2010, 14:12 »
I found the key to stopping the leaks was to tuck the sheet in at the bottom. Also, as you can kind of make out in then picture I tucked the sheet back underneath itself to create a channel for the water to run down instead of seeping through the duct tape.
Then tape the sheet so that the channel will run in to bottom of the door, and the rest of the sheet so it is tucked into the void space of the door  :smiley:
