Author Topic: m2 8v turbo conversion  (Read 7287 times)
Offline stew8vmk2golf
« on: 14 August 2003, 11:22 »
any one help me at all. Im looking at turbocharging my mk2 gti, its a 1990 8v digifant, i was wondering if anyone knows any companies which do a conversion for my car or if its possible to fit the manifold and turbocharger from a TD. I have been told that the air flow meter will work ok and that the current digifant II ecu would also work ok. This may sound a stupid question but are the manifold shapes different on an 8v and 16v??
Offline mk1
Re:m2 8v turbo conversion
« Reply #1 on: 14 August 2003, 18:32 »
Have turbo on my mk1 gti. Did the turbo diesel conversion. Get yourself a exhaust manifold and turbo off a diesel, turn manifold upside down and fit it to the engine (some grinding required tho fit). Loosen the bolts on the compressor housing and rotate it to face in the direction needed. The rest is easy enough, oil supply and return,inlet pipework, etc. You will have to make up your own down pipe. Recomend you use a intercooler, I am running at 9 psi boost on standard comps, had some pinking but have overcome that. Clutch has started to slip now  :(, ahh well, the 2 ltr 16v turbo project has just been brought forward ;).
PS. My conversion was on a mk1, not sure about clearance issues with the rear engine mount on a mk2. This is a good junk yard turbo project, dont think you could turbo a car and get so much for so little ???s. Good luck, Steve.
« Reply #2 on: 14 August 2003, 21:10 »
what about the fueling, what is the best way to sort this, as when running boost the air flow meter wont recognise such high pressure will it???
« Last Edit: 14 August 2003, 21:12 by stew8vmk2golf »
Offline mk1
« Reply #3 on: 14 August 2003, 21:46 »
I use a pressure switch to fire the cold start injector. With your digifant, you could trick the ECU inputs from the coolant temp sensor, or alter the fuel pressure to the injectors when on boost. Steve.
« Reply #4 on: 14 August 2003, 21:58 »
so i could actually run a turbo on my car without changing the ecu or the airflow meter? how would i alter the fuel pressure when its on boost???
Offline mk1
« Reply #5 on: 15 August 2003, 21:30 »
Well, you could fit a pressure regulator that can "see" the manifold pressure increase and restrict the tank return from the rail to increase the amount of fuel injected for the same injector dwell time.
My conversion was on a K jet, so anyone feel free to advise for a digi set up. Good luck, Steve. ;)
Offline modulater
« Reply #6 on: 16 August 2003, 10:53 »
interesting stuff MK1. I'd be interested to know how the 2 litre Gets on when its done. I always thought that when turbo charging you have to fit a thicker head gaket or a spacer to lower the compression ratio so that your not gonna blow anything.
Offline mk1
« Reply #7 on: 16 August 2003, 20:02 »
I am lowering the compression ratio by machining the top of the pistons as fitting a spacer or two head gaskets will alter the cam timing. You can run with standard compression as long as you run low boost and intercooler and moniter fuel ratio. My set up seems ok at around 9psi, with standard comps, but I have had to make some mods to stop pinking.
« Reply #8 on: 16 August 2003, 21:09 »
if i was to fit a g60 ecu what would i need to add to the current loom? I know i'd need to wire in a lambda probe, is there anything else?
« Reply #9 on: 18 August 2003, 23:34 »
"Well, you could fit a pressure regulator that can "see" the manifold pressure increase and restrict the tank return from the rail to increase the amount of fuel injected for the same injector dwell time."
So how would that work? Where could i get one of these from and how would it wire up?
 Is there any one with an idea of how I could set this sort of thing up on a digifant II setup?
