Author Topic: wanting a remap but got theses codes?????  (Read 1889 times)
Offline webz
« on: 25 August 2010, 21:11 »
really want a remap but these things are putting me of having one, what are they and any chance in letting me know how to fix them? please
says (shorting to cylinder) for the cylinder ones
01249 - Fuel Injector for Cylinder 1 (N30)
        26-10 - Output Open - Intermittent
01250 - Fuel Injector for Cylinder 2 (N31)
01251 - Fuel Injector for Cylinder 3 (N32)
01252 - Fuel Injector for Cylinder 4 (N33)
01262 - Solenoid Valve for Boost Pressure Control (N75)
00561 - Mixture Adaptation
        15-10 - Adaptation Limit (Add) Not Reached - Intermittent
Readiness: N/A
Saturday,10,April,2010,17:14:36:59303
VAG-COM Version: Release 704.1
                Address 03: ABS Brakes
Control Module Part Number: 1J0 907 379 Q
  Component and/or Version: ABS/EDS 20 IE CAN  0001
           Software Coding: 13504
            Work Shop Code: WSC 00028
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
        16-10 - Signal Outside Specifications - Intermittent
Offline topher
  • Administrator
  • fully functioning
Re: wanting a remap but got theses codes?????
« Reply #1 on: 26 August 2010, 00:01 »
Clear the faults and see if they come back after a drive. Usually the open output errors are simply due to things being unplugged at some point for whatever reason.. although if the faults return check wiring/fuses/earths. The ADD trim code will most likely be a leak in the pcv (breather) system somewhere so look for telltale signs of built up oil and gunk on the pipes under the inlet manifold. It could also be a faulty maf though so more investigation would be needed if you can't find any leaks.
The ABS one isn't likely to cause issues with a remap other than having the ability to stop, you can find some tips for that code here http://wiki.ross-tech.com/wiki/index.php/01276
