Author Topic: FLAT BATTERY KILLED MY MFA!! HELP ;)  (Read 2053 times)
Offline stockdude
« on: 25 August 2010, 15:00 »
Hi,
My Rivage has been fine with the MFA working on all functions bar engine temp I'll come onto that)
Recently the battery went flat as my Dad left the lamps on.
Since re-starting the car the MFA has shown 'P2 ' on the display - I would assume this is an error code??
How do I clear this???
Also which sensor provides the engine temp - as I might as well do this as well
Many thanks
Re: FLAT BATTERY KILLED MY MFA!! HELP ;)
« Reply #1 on: 25 August 2010, 15:02 »
pull dash fuse for 30 seconds
dash coolant temp sensor is single pin black one in the coolant flange with red/yel wire, oil temp is single pin one in oil filter housing with green/black wire
Offline stockdude
« Reply #2 on: 25 August 2010, 15:51 »
Hi when you say Dash fuse is there a master one?
Will this be in the fuse box and would you know the number?
« Reply #3 on: 25 August 2010, 15:54 »
its on the fusebox, the fuse numbers are in my fusebox faq in the mk2 maintenance section, you need to look for the pre-90 MK2 CE1 fuse/relay layout diagram which is on page 2 :)
