Author Topic: Rattle on start up. SAP running  (Read 994 times)
Offline Big Tone
« on: 24 August 2010, 13:19 »
Hi, I am experiencing a rattly start up. This only happens when first starting in a morning, when the secondary air pump is running.
I have recently replaced plugs, coil packs, vac and boost hoses and car is running good, apart from this rattly sound.
I have also replaced the rivets on the sap.
Anyone have this before?
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline Mr_Orange
Re: Rattle on start up. SAP running
« Reply #1 on: 24 August 2010, 17:55 »
Thin oil and dry tappets (before the oil gets pumped around)?
Build thread clicky
Offline Big Tone
« Reply #2 on: 25 August 2010, 06:55 »
Possibility I suppose as oil is 5w30, but it is only when the sap is running, coincidence?
Offline Mr_Orange
« Reply #3 on: 25 August 2010, 17:12 »
Is it possible to disconnect the SAI pump and fire it up, see if the noise persists?  Most you might get is a code that you'll have to delete afters.
Build thread clicky
Offline Big Tone
« Reply #4 on: 25 August 2010, 20:25 »
Will try that, I will let ya know, at least I will know where it is coming from. Ta
