Golf mk5
Windscreen misting up
Topic: Windscreen misting up (Read 2641 times)
DaveJ
23 August 2010, 22:12 »
Recently my windscreen has started misting up as soon as I start driving even if its quite warm and dry outside. This is with the climate control switched off. I`ve read on here people saying about dodgy climate systems on older GTI`s, mines an 06. I was thinking of maybe having a look at the pollen filter but I can`t think of anything else as I`m pretty sure there isn`t any leaks anywhere
Anyone got any ideas?
Wayne
Sir Postalot
Re: Windscreen misting up
23 August 2010, 23:47 »
Pollen filter or air con issue.
bobotheclown
25 August 2010, 13:51 »
My windscreen did this when I had to have it replaced. I simply used a bit of rainx and it hasn't done it since. That was 2 years ago.
DaveJ
25 August 2010, 17:46 »
Ah right cheers, it does need a good clean inside and out to be fair, will give it a clean and see how it is.
Gene Hunt.
27 August 2010, 08:20 »
I think this time of year you will get a small amount. Change pollen filter,about eight quid from dealers & just make shure screen is clean.
Candy White ED35.
Golf mk5
