Author Topic: question on Injectors for 16Ver lads  (Read 1302 times)
Offline clipperjay
« on: 23 August 2010, 14:43 »
Well its been so bloody long since I've worked on the old gal I can't remember how far the ends of the injectors should stick out of the manifold collets? I've got them so the tip is just on the outside of the end collets. I can't remember is they protrude further? Anyone got pictures how far they stick into the block?
Jay
Offline clipperjay
Re: question on Injectors for 16Ver lads
« Reply #1 on: 23 August 2010, 15:02 »
Sorted its does go past the collets by about 3-4mm :lipsrsealed:
Offline Agreeable Slick
  • Unit
« Reply #2 on: 23 August 2010, 15:11 »
Was going to say, injecter will typically sit in reasonably far as it's a DI engine.
Offline clipperjay
« Reply #3 on: 23 August 2010, 15:37 »
They are tighter than a sixth former in a mini skirt!  :tongue:
I've tried to bang a flat rod to it with rubber hammer and still the fooker won't go past the end collets. Not sure if they will piss fuel out if I just leave them in that position alone?
Looks like a press jobbie but some tips from others would be good?
I lubed up the rubber donut and bang it in for all she's worth and its in now thanks all!
 :smiley:
