Author Topic: 16v Gti Hubs onto 8v driver?  (Read 1211 times)
Offline Thrash_cj
« on: 22 August 2010, 15:39 »
hi,
i need a new n/s/f hub for my golf as the clever people at the garage cross threaded all the bolts in the hub.
They told me it wasnt them and it was my fault, so after a lot af arguing i told them what i thought and was going to give trading standard an email.
So to the point, will the hubs off a 16v gti fit on to my driver or will i need to change the ball joint aswell?
Cheers for the help
Thrash
Had
VW Golf mk2 Driver
VW Golf mk3 16v GTI
Have
VW Golf mk4 GTTDI
Re: 16v Gti Hubs onto 8v driver?
« Reply #1 on: 22 August 2010, 16:33 »
From memory they should all be the same.
« Reply #2 on: 23 August 2010, 09:58 »
Assume this is MK2 Golf we're talking? If so 88 onwards 16v has 256mm brakes, bearing carrier assembly will fit but you'll also need to fit the discs, pads, calipers & carriers, plus do both sides obviously  :tongue:
pre-88 16v has same bearing carrier assembly as your car so direct swap. ball joints on all MK2s changed size in 87, but best to double check what you have as you never know some pleb may have fitted the wrong bits to your car in the past.  you could just press out the hub and press in another with a new wheel bearing.
many MK3 4 stud cars have the same hubs as yours as well, check the size of the brakes. if 239 direct swap, 256+ need to fit the discs, pads, calipers n carriers as well.
« Last Edit: 23 August 2010, 10:00 by rubjonny »
Offline Thrash_cj
« Reply #3 on: 24 August 2010, 10:28 »
Sorry, yeah it's a mk2 driver.
I've got the hubs calipers carriers discs and pads so basically the fully front end braking.
I'll try them on when they turn up and if they fit and i have the time (work never seems to end as of late) I'll try and throw together a how to
cheers for the info
Thrash
Had
VW Golf mk2 Driver
VW Golf mk3 16v GTI
Have
VW Golf mk4 GTTDI
