Author Topic: 1994 golf 2.0 8v engine code 2e fuse box has been cut about  (Read 2995 times)
Offline mike_E
i could really do with some help i had brought this car and found that whilst driving it the car would stutter after 3000rpm and loose power on hills i have check most things i have put car on diognostic and no codes found so i looked at the relays and the wires have been cut and joined looks a right mess think they may have removed an alarm/imobiliser. i have small plugs not joined and it seems like the fuel pump relay is bypassed which i think is number 12 (80printed on it) the relay dosent warm up and it makes no difference if i unplug this. and also should the fuel pump be going continuasly with the ignition on without starting the engine, or dose it cut out when its upto pressure  if someone had any ideas what i can do to wire the fuel relay back in.I really really like this car and want to sort it out some how cheers
kells
Re: 1994 golf 2.0 8v engine code 2e fuse box has been cut about
« Reply #1 on: 21 August 2010, 18:07 »
fuel pump will prime for a few secs on the first turn of the key mate
Offline mike_E
« Reply #2 on: 21 August 2010, 18:18 »
so they have defo bypassed the fuel relay
kells
« Reply #3 on: 21 August 2010, 18:24 »
sounds like it dont it
Offline mike_E
« Reply #4 on: 21 August 2010, 19:26 »
[/quote
any ideas on what i could do
Offline mike_E
« Reply #5 on: 21 August 2010, 19:47 »
i found out that the fuel system has its own wiring loom but not 100% sure  if so has anyone got a wiring diagram of this becuse i have wires not conected and need to know if they have anyting to do with fuel loom then i may be able to rewire the relay back in. also do the wires for the fuel system conect into a block next to the fuse box because i dont see any were for the extra wires to plug in. i could do with a picture of the back of the fuse box im sure this will help me
« Reply #6 on: 23 August 2010, 09:19 »
pm me your email address i have a few wiring diagrams
Offline boneybradley
  • Back in a Mk3...
« Reply #7 on: 23 August 2010, 20:35 »
I don't know if this will be any help but I have used this diagram on several different mk3's over the years
http://www.golfgtiforum.co.uk/index.php?topic=74087.0
Offline mike_E
cheers for the info that you gave but the only diagrams i can find are not of the 2e engine code and it seems that the colours of the wires are different im gunna have a look tomorrow to see which coulored wires i have a problem with and then i will post just to see if anyone can shed some light on what they are for cheers again
i done it all happy now didnt want to give up and persistnce paid off thanks to the people who replied
« Last Edit: 24 August 2010, 20:52 by mike_E »
