Author Topic: DSG problem  (Read 1644 times)
Offline Ugiol
DSG problem
« on: 21 August 2010, 14:56 »
I couldn't find any information on this particular problem that I experienced today whilst driving home so hopefully you can help.
Bear in mind my car has just had a major service, dsg oil change and new cam belt 3 weeks ago. It's an 05 model with 39.5 miles on the clock.
Basically, when trying to push the gear stick over to manual mode, it kept springing back. Eventually after a few tries it engaged as normal but then I find it won't go into S from D without almost forcing it in. That seems to have cleared up but now when putting it into S mode is just springs back into D, much like when I was trying to put it in manaual mode.
Unfortunately, my local dealer is shut. Any ideas about what's happening? I hope it isnt too serious/expensive!
Thanks
Offline _redders_
Re: DSG problem
« Reply #1 on: 23 August 2010, 09:18 »
I heard once that the gaitors around the gear selector are a bit tight from factory and that some plastic somewhere within can break causing this very problem, was in golf + mag a few months ago, think the solution was a new gaitor/plastic trim/knob which from the dealers is pricey, but sure a breakers will have one. Worth a look anyway.
DROP IT LOW . . . ROLL IT SLOW
Offline Ugiol
Re: DSG problem
« Reply #2 on: 23 August 2010, 15:08 »
Thanks, that's very good to know.
I've contacted the dealer who did my service and they are ringing me back today.
I'll let you know how I get on.
