Author Topic: handbrake light "mk3 golf gti 16v 97"  (Read 2446 times)
Offline essexboy123
  • facebook: jon dervish
« on: 19 August 2010, 16:17 »
was driving along the other day and the handbrake light came up, handbrake obviously wasnt on, so i pulled over to check the brake fluid as this can also bring that light on, brake fluid was perfect. since then after iv been driving for about 10 mins it comes on. dont think its anything to do with wiring as the light does not flicker when the handbrake is moved, iv also scanned for faults and cant find any, Im stumped, any 1 have any idears??? :undecided:
Re: handbrake light "mk3 golf gti 16v 97"
« Reply #1 on: 19 August 2010, 16:21 »
Switch under handbrake faulty / failed
Offline snifferdog
« Reply #2 on: 19 August 2010, 16:27 »
If its not the switch, I bet its the abs pump!
Offline essexboy123
« Reply #3 on: 19 August 2010, 16:45 »
surely the abs pump would bring on the abs light not the handbrake light, it should also bring up a fault code on the ecu whitch it hasnt, and iv checked the switch seems to be working fine... really at a dead end, in the manual it says that light (!) is only responsible for the handbrake and the  brakefluid
« Reply #4 on: 19 August 2010, 23:55 »
Will not be the abs pump, faulty sender on the fluid bottle.
Offline jimmyb
« Reply #5 on: 20 August 2010, 14:14 »
it wouldnt suprise me, probs will be  the switch under the handbrake though.
Offline todd
« Reply #6 on: 20 August 2010, 17:42 »
it does come on with abs faults as mine does but only comes on after 10 mins or maybe longer untill the light comes on all i get is a constant buzzing noise bloody annoying
