Author Topic: Problem with my 1.6 mk2  (Read 1150 times)
Offline dymo
  • VW Jetta MK2 coupe
« on: 19 August 2010, 10:07 »
I have Jetta mk2 1.6 with piersburg 2e2. Suddenly appeared such problem that with warm engine the idle is so low and some times engine dies when no gear on or i dont give gas.
My this helps.
with non-working engine this 3/4 unit or something like this looks like this:
and with working engine :
Re: Problem with my 1.6 mk2
« Reply #1 on: 19 August 2010, 11:15 »
when engine running its retracted too far, thats the over-run position. check the 2e2 faq, i suspect you have a disconnected vacuum hose or you have lost power to one/both of the electricl boxes on the back of the carby.
i see what looks like a snapped wire hanging down in pic 1, this could be the reason
Offline Cory
« Reply #2 on: 23 August 2010, 18:26 »
as above. was a vacume hose for me when i had what sounds like the same problem as you.
