Author Topic: engine mount  (Read 1250 times)
Offline dhorsfall2000
engine mount
« on: 18 August 2010, 13:06 »
hi all, ive been getting a bangin noise from somewhere, which i thought was coming from the passenger side of the car, but doesnt seem to bang/knock when going over speed bumps slowly, so i had a look and i seem to be able to push and pull my engine back and forth quite a lot ( i think) with out to much hassle (not very difficult to move) should i be able to move the eninge like this, it appears to move quite a lot around the gearbox mount..
vw golf 2.0, gti, eng code is azj
Offline Adam
Re: engine mount
« Reply #1 on: 18 August 2010, 13:13 »
I would have a look under your motor for your dogbone mount, check its still in place or it hasnt got any excessive movement -
Down Hill From Here.
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: engine mount
« Reply #2 on: 18 August 2010, 14:01 »
As above Dogmount bushes are knackere or you have snapped the mount.
Re: engine mount
« Reply #3 on: 18 August 2010, 14:25 »
ive had a quick look at the dogbone mount, ther does seem to be a bit of play in it, gonna have a good look tomorrow, how much play should it have in it??
Offline Hulmie
Re: engine mount
« Reply #4 on: 18 August 2010, 15:37 »
Shouldnt really be any play mate. May just a ickle bit of movement.
Worth replacing the bushes as they will go eventually. Upgrade to Poly bushes
Offline tech1889
  • Mk2 GTI FTW !!
Re: engine mount
« Reply #5 on: 18 August 2010, 19:30 »
whats the best dog bone mount bush ??
Offline houston
Re: engine mount
« Reply #6 on: 18 August 2010, 21:11 »
depends what your after, powerflex take a lot of engine sway out and make the gearchanges seem easier, but it can get very harsh. some people only use one of the bushes from the kit so its not as bad
everyday use id go for an r32 mount.
Re: engine mount
« Reply #7 on: 25 August 2010, 17:46 »
an update on my knocking problem :
had it in the garage for tracking doing and asked them to have a look to see what the banging was, they couldnt find anything wrong with it, they said theyd had the bar in it just like an mot and there is no play in any of the suspension parts. they r puzzled
