Author Topic: help fitting KW coilovers  (Read 2175 times)
Offline tim8v
« on: 18 August 2010, 11:26 »
I am starting to build my MK2 for the GTI championship, and as such I am on a tight budget. I would like to try and do some of the work myself, so is there a guide to removing the standard suspension so I can fit coilovers? I know there is a sticky on here about changing the springs, would that be ok to use as a guide?
Any help would be appreciated!
Golf MK2 8v Race car (Work in Progress)
Offline SoundillusioN
Re: help fitting KW coilovers
« Reply #1 on: 18 August 2010, 11:33 »
try http://forum.performancevwmag.com/viewtopic.php?t=40697
Offline banterchicken
« Reply #2 on: 18 August 2010, 18:41 »
I found it a pain in the arse if im honest. Still havn't got around to doing it!
Offline Ben Lessani
« Reply #3 on: 18 August 2010, 19:45 »
Its only about 4 bolts per corner - piece of pi$$.
Its mostly common sense - remove whatever bolts are in your way.
on the front 2 bolts off the wheel bearing housing, then remove the securing bolt from the top mount ... done
on the rear 1 bolts off the rear beam, then remove the securing bolt from the top mount ... done
There's a really vague how-to on changing rear top mounts here: http://www.golfgtiforum.co.uk/index.php?topic=49436.msg1383398#msg1383398 - removing the whole shock is just 1 more bolt.
Can't imagine it taking more than 1-2 hours to do.
