Author Topic: Noisy heater  (Read 3936 times)
Offline pipworks
Noisy heater
« on: 13 August 2003, 16:28 »
Hi, does anyone know if there's a way of quietening the heater fan on a MK2?
On speed 1 it's an annoying rumble, 2 it's an ear piercing squeal, and 3 causes my eardrum to puncture and start bleeding! Ok, that's last one was a slight exaggeration, but it's annoying as hell whichever setting I use.
A new fan unit from VW is stupid money, and WD40 only lasts a few days, it's a lot of work for a few days peace and quiet.
TIA
Pip
golfvr6
Re:Noisy heater
« Reply #1 on: 13 August 2003, 22:21 »
Try a scrapyard maybe?
Offline pipworks
Re:Noisy heater
« Reply #2 on: 14 August 2003, 10:32 »
Yeah, did that before, the original one stopped altogether, this one was ?25 and they don't guarantee them not being noisy!
Offline richandhazel
Re:Noisy heater
« Reply #3 on: 14 August 2003, 10:41 »
Think you might have to take the hit in the wallet. Any measure you take to quiten your current one is only going to be temporary. You could try '87_PROJECT', I gave him one out of my old Mk2 that was OK............he may be willing to pass it on.
Offline Dizzie
  • Make friends with your fast
Re:Noisy heater
« Reply #4 on: 14 August 2003, 11:35 »
noisey heater? I've got one of those too :D
usually when you turn it up to 3 it stops making the noise, but now it just gets worse. Time to buy another from somewhere.
Offline tinman
Re:Noisy heater
« Reply #5 on: 19 August 2003, 01:26 »
I think the problem is that water leaks into the interior fan and corrodes part of the spindle. Hence the excess noise.
Regards,
Justin
Offline Dizzie
Re:Noisy heater
« Reply #6 on: 19 August 2003, 21:54 »
?10 from the scrappy. That Jetta with a Fiesta on it's roof won't be needing it anymore. Ahh, bliss. No more whining now :D
Offline modulater
Re:Noisy heater
« Reply #7 on: 19 August 2003, 23:01 »
I would try lubbing the spindle up first, I would imagine there must be a bearing in there that has gone dry with the heat passing through. Use some silicone spray or something similar.
Offline pipworks
Re:Noisy heater
« Reply #8 on: 20 August 2003, 11:46 »
Ah silicone spray, genius!!
Thanks, will try that!!!
Offline tizer2000uk
Re:Noisy heater
« Reply #9 on: 25 August 2003, 09:11 »
Silicon spray or grease on the spindle will shut it right up, mine started doing that a few weeks ago.
