Author Topic: locking wheel nuts how do i undo em!!  (Read 8514 times)
mk1heaven
« on: 05 June 2003, 17:48 »
Does anyone have any idea?s about unlocking a locking wheel nut!!! I bought a MK1 gti and it had a set of horrible 16 inch alloys on. However when I came to change the brakes I tradically came across a set of locking wheel nuts and I have no nut/ ???KEY!!! Any ideas?
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
jelly
Re: locking wheel nuts how do i undo em!!
« Reply #1 on: 05 June 2003, 18:33 »
drill two holes in them and use a pare of pliers???
Offline VWnut
« Reply #2 on: 05 June 2003, 21:05 »
If  that fails take it to a garage and get them to weld a nut to the locking bolt, then just use your wheel brace.
Offline deano
« Reply #3 on: 09 June 2003, 23:26 »
I had a similar problem with my alloys (i broke the key),
main dealer wanted ?60 to drill them off, sod that.
I took it to a local tyre fitters and they hammered a nut over the top and it came off no probs.  ;D
« Last Edit: 01 January 1970, 01:00 by -1 »
Offline firefighter
Re:locking wheel nuts how do i undo em!!
« Reply #4 on: 26 June 2003, 19:50 »
I have seen a tool to remove locking wheel nuts in a tool shop at the Metro Center in Newcastle. ;)
Offline a9wyn
« Reply #5 on: 29 June 2003, 20:38 »
had the same problem with the three hole type locking wheel nut ,one of the holes became elongated due to some nice tyre fitter over tightening them , tried various sources for advice for removal which icluded anything from semtex to grinding the bolt head off (without damaging the wheel?) in the end and in desperation went to my local VW dealer where they removed in approx. five mins by hammering an undersize socket over the bolt head and undoing and the best part they didn,t charge me not even for the socket they used and broke i assume.......wyn
Offline MK1_BOY
  • Low Low bored out MK1 Golf GTI Campaign.
« Reply #6 on: 30 June 2003, 17:55 »
I've got a sledge hammer if you want to borrow it..
Race ya...
Offline VWaxilMK1cab
  • 1992 mk1 cabrio gti
« Reply #7 on: 01 July 2003, 16:47 »
Gaitor grip i think is the name, it's like a socket with little pins in it which fit around anything you could want to undo.
Offline tinman
« Reply #8 on: 01 July 2003, 20:12 »
so just run this past me - if there is a tool available - why do we use locking wheel nuts in the first place?
sort of defeats the object of the exercise doesn't it?
Regards,
Tin
Offline Dean
« Reply #9 on: 03 July 2003, 01:14 »
I had to get my locking nuts removed today, took it to a tire fitting place and they brayed a 21mm socket over the nut and removed, cost me ?8, plus ?15 for a new set of nuts.
Regards.
Dean.
« Last Edit: 03 July 2003, 01:14 by Dean »
I am just a mere pawn in the great game of LIFE!
