Author Topic: cam cover gasket  (Read 2063 times)
Offline spear
cam cover gasket
« on: 17 August 2010, 15:23 »
I'm planning to change the cam cover gasket on my 16v this weekend and wondered if someone could tell me if i should replace any of the bolts whilst I'm doing it? I was going to get some spares in case I destroy any during removal but which bolts do i need?
also read about some gasket seal that some people apply on the corners, is this necessary or am i ok without it?
thanks ina dvance for your suggestions, want to do it right first time!!
Re: cam cover gasket
« Reply #1 on: 17 August 2010, 15:39 »
you need just a smidgeon of sealnt in the corners of the humps over the cam sprocket and dizzy ideally otherwise it will leak a bit. cant remember the type off hand but it comes up on ebay from time to time, same stuff as used on the later models for the sump.  most abfs use hex nuts on the rocker cover, so check which you have before you start. upper half of inlet manifold needs to come off but the allen bolts for this should be ok as they're easily accessible
Offline MotorPsycho
  • I drive a 2000bhp dragster, so what ;)
« Reply #2 on: 17 August 2010, 17:42 »
make sure you get the right gasket as well, there's two types
early ABF's (I think and maybe Seat ABF's) use the same rocker cover/gasket as the 16v KR from a mkII, which has a raised section all the way round the gasket which sits inside a groove on the rocker cover
later ABF's use a flat gasket and no groove on the rocker cover
I found this out the annoying way :(
1983 mk1, 2.0, TSR pack C head, Eaton M45 - work in progress
1990 mk2 GTD, boost, fuel, soot
16v GTi mk3; chilli red, 16" Audi Speedlines, coilies
1934 Ford Dragster, 200mph in 6 seconds.
Offline Paul86S2
« Reply #3 on: 17 August 2010, 19:15 »
As stated make sure you get the correct gasket, early ones are differant.
You will also need the gasket for the top half of the inlet which needs to be removed. I would only replace the bolts if they are knackered.
Paul
« Reply #4 on: 18 August 2010, 10:17 »
early cover = bolt fixing, late cover = nuts :)
Offline spear
« Reply #5 on: 18 August 2010, 10:46 »
its a P reg so must be the later one.
I got the gasket from Euro Car parts last year but never got round to fitting it, hope its the right one!!
Offline spear
« Reply #6 on: 18 August 2010, 11:16 »
this looks like the one i have but i'll have to check when i get home to make sure, seems more expensive than the one i bought though  :undecided:
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_1996/p/Car-Parts/Engine-Parts/Engine-Parts/Gaskets-and-Seals/?368440480&1&d4c88bc54f6163c90c3ef0f98fdb29746946a147&ROKG
also do you know the part number of the inlet gasket, I have a GSF nearby that i can pop into to get one.
Offline Paul86S2
« Reply #7 on: 18 August 2010, 13:46 »
P Reg will be the later gasket. Looks like the right one.
Inlet gasket is part number 037 129 717 E
Paul
