Author Topic: flashing header tank empty guage  (Read 1530 times)
Offline g858
« on: 14 January 2005, 15:17 »
Hi all,
Time to test your knowledge!!
I've got a MK2 1800 8V which a warning light keeps flashing on the dash. Its the one which signifies that the header water tank is low. I've check this and its not,  its up to the max. Checked the connections and all seem ok. Wiggled wires and other sensors but no joy. Everything else seems to be working fine ie fan, thermostat etc.
Any ideas what might be wrong, as i've got a long trip soon and don't want any hassle.
Any help would be much appreciated.
Offline Dizzie
  • Make friends with your fast
Re: flashing header tank empty guage
« Reply #1 on: 14 January 2005, 15:19 »
is it leaking at all? anywhere on the system, not just the tank.
Mk4 Golf 150PD
Offline Gambit
« Reply #2 on: 14 January 2005, 16:06 »
replace the sensor or check the earths, only about a ?5 or something from EuroCarParts
Offline g858
« Reply #3 on: 14 January 2005, 16:43 »
I think it maybe leaking a tiny bit, but hardly any. Not enough to worry about i don't think, but i'm no expert!!
Offline g858
« Reply #4 on: 14 January 2005, 16:47 »
Is it simply an expansion tank sensor i would need then, or something else?
Offline ...joe
« Reply #5 on: 14 January 2005, 17:32 »
when you check the water level is the car up to temperature? if so check it when its cold and see what level its at. they work on a pressure system and when hot the water level rises so would give you an inaccurate reading. test it cold and add antifreeze/water if needed and see if that makes any difference.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
