Author Topic: central locking kits  (Read 3110 times)
Offline mk2bal
« on: 15 August 2010, 18:05 »
im going to fit a toad ai606 to the golf, but as it started as a non gti its not got central locking. ive heard of kits off ebay,but theres tonnes to choose from,can anyone recommend one maybe? i only really want the drivers door to unlock, so might not even bother installing passenger 1.  if i got a universal 1, would i just not use the cheap fob that comes with it, wire it up to the toad and have that do it all yeah?
Re: central locking kits
« Reply #1 on: 16 August 2010, 13:23 »
the toad should be able to control a bog std aftermarket 2 wire cl actuator direct, just chuck one o them in drivers door hooked up to the alarm and bobs your uncle
Offline jp123
« Reply #2 on: 16 August 2010, 17:46 »
what about if you dont have an alarm? still a simple job to fit a central locking kit
« Reply #3 on: 17 August 2010, 10:10 »
yeah just buy an aftermarket cl kit and fit it, pretty easy with a bit of thought.  i recommend the rclick.co.uk kits, best quality of all the ones i have installed
Offline mk2bal
« Reply #4 on: 17 August 2010, 21:02 »
well im not gonna bother sourcing and fitting an old vacuum style one with all the bits, just wanted to know if theres any real chewy ones that should be avoided. ive found an oe electronic central locking kit, genuine from vw for cars not fitted originally, so when that comes through ill check to see if its any good for the job,should be able to suss it out. rj you'll probably know, when fitting the toad to the door pins do i need a diode soldered in, its something to do with the pin being normally open or normally closed, wether it goes to earth or goes to 12v or somethin. im guessing it goes to earth? '91 mk2 16v btw
Offline dubvrs
« Reply #5 on: 17 August 2010, 22:47 »
I have one of these kits on my mk2
Works well plus you get a remote boot pop. You get a complete kit.
http://cgi.ebay.co.uk/Central-Lock-Locking-Kit-Remote-Keyless-CLR669W-ULT-/380232793979?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5887a3ff7b
Pic of the keys i had.
Offline Ricardo Da Force
« Reply #6 on: 05 October 2010, 20:27 »
Be careful with some of the alarm/central locking systems on e-bay. Apparently they have to be sold without the option of turning the auto-arm off.
If you don't know this it may cause a problem, in my case when the key were in it!
Offline Ben Lessani
« Reply #7 on: 05 October 2010, 20:35 »
Most auto-arming alarms don't lock the doors, they just arm the alarm for that exact reason ;)
