Author Topic: New fusebox easy fit?+ Fuel relay burnt  (Read 1529 times)
Offline Alps
« on: 13 January 2005, 22:56 »
How easy is it to fit a new fuse box?
When i bought my mk1 rivage, it had a burnt out fuel relay which had been replaced, but it had damaged the connectors on the fuse box, so to start you sometime have to wiggle the relay!
ive changed the fuel pump in case that was the cause, havent changed the top pump (should I change that too?)
The interior light stays on really dim if i put it to come on on the door, and the right front light is dim.
im thinking its all to do with the burnt out fusebox.
I have a spare one, is it a easy swap?
thanks
Alps
Mk1 Rivage - 1992 Green
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
MK1 Rivage - 1991 Blue SOLD
Offline Dizzie
  • Make friends with your fast
Re: New fusebox easy fit?+ Fuel relay burnt
« Reply #1 on: 14 January 2005, 11:58 »
easy as pie. just remove the old one and plug the new one in it's place.
Mk4 Golf 150PD
Offline Alps
« Reply #2 on: 16 January 2005, 09:21 »
so half a days work then?
Alps
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
Offline Dizzie
« Reply #3 on: 16 January 2005, 13:46 »
halfhour/hour most!
Mk4 Golf 150PD
Offline Alps
« Reply #4 on: 23 January 2005, 19:04 »
ok, took me a total of an hour, disconnected the battery, then unplugged all the plugs, and reconnected the new one , sorted, started first time too!
- fixed the fuel reley problem and
- fixed the horn - must have been a faulty relay on that too!
Alps
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
