Author Topic: MK4 2.0 smokey! please help  (Read 1982 times)
Offline djhixxy1983
« on: 14 August 2010, 20:48 »
Hi new to this VAG thing and i seem to have problems with my MK4 GTI
Its just recently started smoking when hot. it doesnt do it all the time. only when its warmed up and i sit in traffic or at lights. then when  pull away it give a puff of grey smoke and is then fine. thought it might be head gasket but no oil and water mix and no sludge on the oil cap.
thought it might be stem seals but they seem fine. also cleared the breather system. bit gunked but nothing major. A friend has said it could be overfuelling and the smoke does smell rich and not oily.
please help!
Offline Diamond Hell
  • Opinions я Us
Re: MK4 2.0 smokey! please help
« Reply #1 on: 15 August 2010, 06:33 »
Thank heavens there was only one engine fitted to a Golf4 GTI.  It means diagnosis from this sort of information is dead easy....... oh hang on, there were about four or more quite different engines fitted to them.  What is it?
Offline djhixxy1983
« Reply #2 on: 15 August 2010, 14:41 »
??? its a 2.0 8valve. 2001 plate? if that helps
Offline *tell*
« Reply #3 on: 15 August 2010, 15:45 »
2.0 I4 85kW (APK/AQY/AZJ/AZH)
also available as a CNG/gasoline .
stolen from wikipedia  :lipsrsealed:
one of the engine codes should be yours  :wink:.
  • Opinions я Us
« Reply #4 on: 15 August 2010, 19:24 »
Compression test it and come back to us.
« Reply #5 on: 15 August 2010, 23:31 »
It says in the title it is a 2.0  :grin:
Offline danny_p
« Reply #6 on: 16 August 2010, 00:33 »
bluey smoke is valve stem seals.
grey smoke going to be excess fuel,  most likely to be the air mass meter   get fault codes read or if none show look for silly readings.  other likly option is the lambda
all the VW's have gone bar 1.
