Author Topic: Rear Wheel Bearings  (Read 2115 times)
Offline puzzled
Rear Wheel Bearings
« on: 14 August 2010, 13:18 »
does any1 know what size socket to take these off i need..
also what torque setting there done up to ??
Thanks
Offline cняis
Re: Rear Wheel Bearings
« Reply #1 on: 14 August 2010, 16:13 »
Thanks
the hub nuts on the rear stub axle on mk2's with rear discs are no bigger than 24mm for sure, as my socket set only goes up to 24mm  :grin:
when tightening up the new ones, once you've eradicated all slop, you're bearings are tight enough  :tongue: easiest way to check is to leave it jacked up and pop a wheel back on, rock the wheel side to side and top to bottom. dont over-do it though
Offline Ben Lessani
« Reply #2 on: 14 August 2010, 21:26 »
Hand-tight is sufficient.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #3 on: 14 August 2010, 21:59 »
Nip up with the socket attached to a short ratchet, back off till nut is loose, then as Ben says, hand tight is sufficient, refit wheel, and check for excess play, and check that the wheel turns freely
Thom
Offline puzzled
« Reply #4 on: 15 August 2010, 08:44 »
nice 1 cheers every1...
1 last thing for the moment any ideas how tight a knock sensor has to be done up on the engine ??
ive been told 15nm but the haynes book says other wise ?? (had a quick peek in a haynes)
Offline Ben Lessani
« Reply #5 on: 15 August 2010, 09:55 »
20nm is just a nip over hand tight (depending on lever size), 15-20nm should be fine, the torque isn't critical (like on a head), just enough to stop it falling out.
Offline puzzled
« Reply #6 on: 15 August 2010, 10:04 »
bit puzzled by that comment do you know what i mean by the knock sensor ?? (on the engine/ just below the alternator)
Offline Ben Lessani
« Reply #7 on: 15 August 2010, 10:09 »
Offline puzzled
« Reply #9 on: 17 August 2010, 07:31 »
Thanks !!
