Author Topic: brakes, to upgrade or not?  (Read 2282 times)
Offline ASH
  • its a way of life!
« on: 13 January 2005, 20:17 »
right gotta get new front discs and pads, should i just stick to the normal vented (256mm) discs, or is it worth spending more and going down the vented/grooved option?
any thoughts
Offline tinman
Re: brakes, to upgrade or not?
« Reply #1 on: 13 January 2005, 21:43 »
i am the one person on the forum who will be negatitive about this.
grooved disks cut your pads to shreds so wear actually increases on the pads. however the performance gains that you get will never be experienced on a day to day basis. the only time the disk will begin to play a significant role is if you track the car, or take it to somewhere like the Ring.
the key thing about grooves is that they disapate heat quicker, plus they stop a build up of a gas between pad and disk. this only usually happens when the disc and pad are extremely hot. the gas creates a layer and reduces braking performance.
the grooves allow the gas to move away from the disk. if you somehow get the disc on the wrong way round then that effect is negated.
if you are buying grooved discs for the asthetics then they are well worth the money. they do look good.
Offline ...joe
« Reply #2 on: 13 January 2005, 21:57 »
i always thought that the grooves stop your pads glazing over under hard braking. interesting. and yeah they do wear your pads quicker.
every one seems to like the old zimmerman cross drilled and pagid pads, combo from gsf.  they seem to get good reviews.
i ordered some brembo discs from a mate who works at an auto factors and assumed i was getting drilled ones, was gutted when they turned up solid but were so cheap i kept them.
sorry, waffled there! so to answer your question i'd go for the zimmerman/pagid combo. good value for money.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Gambit
« Reply #3 on: 14 January 2005, 09:53 »
grooved disks are to stop pad glazing
drilled disks dissapate heat quicker
stick to drilled!
have a look at porsche & AMG merc's all use drilled disks, no grooves to be seen anywhere!!
VeeDubGTI16v
« Reply #4 on: 14 January 2005, 13:48 »
6 grooved brakes are the best, any more grooves and you loose too much surface area :wink: and i wouldnt bother with cheap drilled discs, they will just crack :tongue:
Offline Dizzie
  • Make friends with your fast
« Reply #5 on: 14 January 2005, 14:16 »
I drilled mine just cos they looked cooler. also the 280mm G60 brakes are far better than the standard gti ones I had before.
VeeDubGTI16v
« Reply #6 on: 14 January 2005, 14:35 »
im getting some new discs soon and from what ive seen/heard the ate power discs look damn good for the money, they are vented and grooved, the groove is like the atomic symbol, are ?60ish for the 280mm front ones :laugh:
Offline Dizzie
« Reply #7 on: 14 January 2005, 15:01 »
my mate has those ones on his rallye
Offline Gambit
« Reply #8 on: 14 January 2005, 15:58 »
ive brembo max on the front of mine  :shocked:  but they came on the car along with the drilled rears
« Last Edit: 14 January 2005, 16:01 by Gambit »
Offline ...joe
« Reply #9 on: 14 January 2005, 18:18 »
i had those ate power discs on mine before the g60 brake upgrade, so on standard 239mm discs. i was quite impressed with them for the money, but they were only grooved, not cross drilled. are the 280mm ones both then?
