Author Topic: Underseat subwoofer  (Read 42990 times)
Offline am1w
Re: Underseat subwoofer
« Reply #50 on: 31 August 2010, 21:39 »
Given how easy it is to safely remove the RNS it's a no brainer to me.
Thanks. I've even got a spare brand new faceplate cover in case of damage! :nerd:
Offline p3asa
« Reply #51 on: 31 August 2010, 22:44 »
Can I ask how much that cost you am1w?
I broke a couple of clips off mine when installing the RNS but it went back on just as tight even with the clips missing but I might be persuaded to buy another one.
Do you also have a parts number?
Offline am1w
« Reply #52 on: 31 August 2010, 23:04 »
It's the only invoice I have not filed. It's in the car which is parked down the road..
Cost approx £16 + VAT.
Offline mike.
« Reply #53 on: 01 September 2010, 10:00 »
According to ETKA, the part number is "5K0 858 061 E 1QB" and is £12.94+vat  :smiley:
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline p3asa
« Reply #54 on: 01 September 2010, 10:09 »
Thanks am1w
Cheers Mike.
That's okay as I thought it might be something ridiculous as VW realise its an item that might be replaced by a few folk.
Offline am1w
« Reply #55 on: 01 September 2010, 13:38 »
Thanks am1w
Cheers Mike.
Part No W5K0 858 061 E1 QB     (033151/TRIM)
Cost £12.94 + VAT :smiley:
Offline p3asa
« Reply #56 on: 01 September 2010, 14:07 »
Cheers mate.  :wink:
Offline DDg
« Reply #57 on: 01 September 2010, 17:16 »
I broke a couple of clips off mine when installing the RNS but it went back on just as tight even with the clips missing...
I used Araldite to secure the clips I snapped off. Couple of days in the airing cupboard and they're a lot more secure than the crappy melted plastic method VW use. If it's in your DIY kit it might save you a few quid...
Offline FroGTI
  • Wheel nut
« Reply #58 on: 02 September 2010, 08:27 »
The RNS is a doddle to remove, but those clips break really easily. I had to remove mine twice and I think there are only about 3 of the 12 or so clips left intact :cry: I think I might invest in a new surround if I have to remove the unit again.
Offline FroGTI
  • Wheel nut
« Reply #59 on: 06 September 2010, 12:19 »
As I said above, I decided to sort the bass out on my Transit van first, as it was really poor (despite my having already installed better door speakers).
I finished the install this morning, very pleased with the result. The sound is much meatier, but not stupidly deafening. The remote is useful as it allows you to trim the response to as little or as much as you want. The trickiest part of the install was, as I suspected, splicing into the speaker output wires at the back of the head unit. There is so little space that I was only able to do the driver's side speaker (the instructions tell you to get a feed from both left and right speakers for better balance). Other than that, it was just a case of following the instructions and finding a permanent positive (battery), ignition on positive and a negative. Having said that, the Transit is far easier to work on than the Golf, because it's built like a 19th century traction engine with loads of space everywhere, accessible screws, humungous bolts and easily removable trim. Also, I'm not nearly so fussy about how the finished result looks - it's a van! :grin:
Here's a quick picture. Not much to look at, but it shows how discreet the install is. You really don't notice it unless you get down on your hands & knees to look under the seats (obviously the sub would have to be located elsewhere in the Golf). I strapped the sub to the passenger seat frame (like the Golf, my van is LHD :smiley:) to avoid drilling through the floor and to make for easy removal on selling the van. It does make the passenger seat vibrate a bit, but I won't be blasting music when I carry passengers anyway. You can also see the slab of compressed foam I fashioned from an old boot liner to cushion the sub against the frame.
I am interested to hear how you others have got on with your subs...
« Last Edit: 06 September 2010, 12:29 by FroGTI »
