Author Topic: Front brake squeel  (Read 2774 times)
Offline waddler
Front brake squeel
« on: 12 August 2010, 18:40 »
Anyone know what the cause is and how long do front pads last?
Offline waddler
Re: Front brake squeel
« Reply #1 on: 12 August 2010, 18:41 »
by the way only squeels at very low speed and light braking.
Offline Phil1980
« Reply #2 on: 12 August 2010, 19:12 »
Have you got any warning lights on your dash, there is a sensor in your front brakes that will let you know if they are worn.  Could just be trapped debris thats causing the squeeling, whip em out and take a look at them.
I would check them just to be sure as sometimes the sensors fail to work, or have been bypassed by a previous owner so they don't get the annoying light on the dash.
MK5 2005 GTI, BLACK, 3 DR, 18" MONZA II, XENONS
Offline waddler
« Reply #3 on: 12 August 2010, 19:21 »
No lights and its been mine since new.  Last setviced 6 months ago by VW and they didnt mention they were overly worn.
Offline bacillus
« Reply #4 on: 12 August 2010, 19:43 »
Look for a small stone or the likes caught up in the brake caliper/disc set up.
Without traction power is nothing!
Offline Saint Steve
« Reply #5 on: 12 August 2010, 20:33 »
Just changed mine. 50k miles, was about 3 mm left on one side. Caliper housings are more then likely full of brake dust, give them a good wash out with the pads off.
Offline waddler
« Reply #6 on: 12 August 2010, 20:46 »
I never tamper with the oily bits myself...:-)
How about I try and get in with a jet washer?
Offline Phil1980
« Reply #7 on: 12 August 2010, 21:05 »
Time to get your hands dirty...... :smiley:
Offline Saint Steve
« Reply #8 on: 12 August 2010, 21:41 »
Jet washer wont be able to clean out inside the caliper housings. Only way to do it is to take the pads out, because its the dust that gets trapped between each pad and the caliper housing.
If you dont want to get dirty hands, its a hours labour at your local garage.
Offline waddler
« Reply #9 on: 12 August 2010, 21:58 »
Well give it a good squirt with a hose and 95% gone so will give it a few more shots and hopefully it'll be gone for good.
