Author Topic: Sunroofs  (Read 1182 times)
Offline chrismorby
Sunroofs
« on: 10 August 2010, 07:40 »
Morning all, i seem to have a leak somewhere within the sun roof. does any one know the week points around the sunroof and how easy it is to change the seals and also the drainage tube that goes from the corners down the pillar and exits by the hinge, how can i check this isnt blocked? or change it if it does? please help im starting to feel like a fish in a mobile fish bowl!
Offline MotorPsycho
  • I drive a 2000bhp dragster, so what ;)
Re: Sunroofs
« Reply #1 on: 10 August 2010, 08:03 »
check the drains first, get a long bit of welding wire of similar and poke it down the holes
1983 mk1, 2.0, TSR pack C head, Eaton M45 - work in progress
1990 mk2 GTD, boost, fuel, soot
16v GTi mk3; chilli red, 16" Audi Speedlines, coilies
1934 Ford Dragster, 200mph in 6 seconds.
Offline chrismorby
Re: Sunroofs
« Reply #2 on: 10 August 2010, 16:59 »
so something fairly soft as i dont want to puncture the tubing inside, if i do pop it how do i replace it>?
Offline VR6_Wherry
Re: Sunroofs
« Reply #3 on: 10 August 2010, 17:06 »
I used a fcuk load of carb cleaner and stuck my finger in the nipples where the cleaner was coming out  :grin:
Offline Stirring Moose
Re: Sunroofs
« Reply #4 on: 10 August 2010, 18:31 »
Be very careful about poking things down the sunroof drains as it is, as has already been mentioned, too easy to puncture the tubes. One approach I tried was to blow them through with a compressed air line, although again it pays to take a bit of care; don't go mental with the air pressure.
S.M.
Love and hate, war and peace, joy and sadness... all just crap that happens between trackdays!
Offline chrismorby
Re: Sunroofs
« Reply #5 on: 11 August 2010, 11:07 »
i was thinking about trying with a air duster for computer parts and a syringe with some warm soapy water in. but if they are or get ruined how do i get to them?
Offline Deano2711
  • 1992 VR6
Re: Sunroofs
« Reply #6 on: 11 August 2010, 11:15 »
The easy way to to slowly pour boiling water down the drainage hole at the top and the water should appear at the bottom of the car. If it is blocked then as said very carefully use something long and thin (and blunt) to try to clear the blockage but the boiling water usually clears them out Mate.
