Golf mk2
which injector for this fuel line??
Topic: which injector for this fuel line?? (Read 908 times)
jamrock
Guest
09 August 2010, 18:00 »
this is the line the injectors currently fit
i want them to fit to the silver painted line. the bigger nut.
there is a difference between the two, i never knew i had to get different sized injectors. i just pushed on the seals!!!!!
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: which injector for this fuel line??
16 August 2010, 12:33 »
the 2.0 16v and later 8vs had a different sized thread on the ends of the injectors as you have just found out
clipperjay
17 August 2010, 15:07 »
cut the ends off and use a smaller nut
if diameter of the old and new pipes are the same
You will need a flare kit that makes the lip on the end to ensure a snug fit thats the only way its gonna half work fella!
http://www.golfgtiforum.co.uk/index.php?topic=170521.0
http://www.golfgtiforum.co.uk/index.php?topic=55336.msg427955#msg427955
Golf mk2
