Golf mk5
Number plate light replacement?
Topic: Number plate light replacement? (Read 1903 times)
Keano
GTI forum regular
09 August 2010, 17:48 »
Hi guys
just wondering if anyone has changed their rear number plate lights for something like the new bright White BMW led/bulbs?
I've read that it could show fault codes or just plainly not work, but it'd improve the rear, no end.
Anyone managed it?
Jimp
Re: Number plate light replacement?
09 August 2010, 19:04 »
I put in different bulbs that are whiter than stock, but not the same blue-whit as on some BMWs or Lexuses. I've read that some brands of L.E.D lights don't cause errors because they have an extra resistor to balance the load. I've also read that some brands run very hot and this can cause the plastic bits of the hosuing to melt
Pictures of mine if you are interested:
http://www.golfgtiforum.co.uk/index.php?topic=107011.0
The light does cover the whole plate, my camera just sucks at night shots.
Not low enough mk5
Not on the road enough mk3
weston
GTI forum regular
09 August 2010, 19:38 »
I changed everything to LED
http://www.golfgtiforum.co.uk/index.php?topic=156137.0
S2 Ant
10 August 2010, 12:29 »
Not checked the link above but they will need to be the resistored type, otherwise it'll flag as having a bulb out, which then cuts the power to the bulbs, so you cant just ignore the warning and they'll be on.
weston
GTI forum regular
10 August 2010, 13:42 »
Yeah they all have built in resistors. Had them in for a few months with no issues at all.
Golf mk5
