Golf mk2
Clock Swaps
Topic: Clock Swaps (Read 3802 times)
Judderi
Guest
Clock Swaps
12 January 2005, 14:18 »
I need to sort the lights out on my clocks and would really like to install these dials.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=72215&item=7947295834&rd=1
The only trouble is mine is a 16v 89 with 160mph clocks. What exaclty would i need to do to swap to 140mph clocks?
Gambit
Forum addict
Re: Clock Swaps
12 January 2005, 14:40 »
to make your clocks work on the 140mph scale you need to change the speedo drive on the gearbox end of the cable
at the mo your's uses the red speedo drive, u need the white one. i have one if you want it
its just a clip off clip on affair
Judderi
Guest
Re: Clock Swaps
12 January 2005, 17:52 »
Yes please. Are my clocks the one plug affair with it being an 89? Hazard on dash.
Gambit
Forum addict
Re: Clock Swaps
13 January 2005, 09:40 »
yes your clocks are the one plug type
im going on holiday tomorrow for a week. so if you can wait a week ill post it to you no bother.
Judderi
Guest
Re: Clock Swaps
13 January 2005, 10:01 »
Yeah that would be great. Thanks
...joe
Forum Supporter
Forum addict
Re: Clock Swaps
13 January 2005, 10:33 »
i looked at these lights too, the only thing i wasn't sure about was how you'd illuminate the needle as these don't allow you to have the bulbs shining on the display, so at night it could be a bit of guess work judging your speed. any thoughts?
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Gambit
Forum addict
Re: Clock Swaps
Reply #6 on:
13 January 2005, 12:47 »
although the faces now glow do the original dash lights still not work also??
Judderi
Guest
Re: Clock Swaps
Reply #7 on:
13 January 2005, 13:22 »
I was going to try leaving the origional clock bulbs going and see what it looked like or try painting the needles white or orange and installing a black light.
Gambit are you sure mine are the one plug clocks? Arnt pre 90's 2 plugs?
Last Edit: 13 January 2005, 15:00 by Mk2GTI2.016v
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: Clock Swaps
Reply #8 on:
13 January 2005, 16:30 »
Hazard on dash means the clocks are the two plug type!
Best way to do it is when you get the replacement clocks, simply swap your old speedo into the new set. That way you keep your milage, dead easy just make sure you keep the correct 'L' shaped circuit board and bit that screws into the rear of the clocks with the right set of clocks
Judderi
Guest
Re: Clock Swaps
Reply #9 on:
13 January 2005, 16:52 »
Yeah i was gonna keep the origional clocks anyway just was a bit confused with gambits message.
Golf mk2
Clock Swaps
