Author Topic: SERIOUSLY WORRIED!! advice please  (Read 2281 times)
Offline wrobstar21
« on: 08 August 2010, 22:43 »
Hi everyone,
about an hour ago my 16v started making a knocking type noise from around the top to top left hand side of the engine. Checked oil and seems ok, maybe a bit low.
The noise increases with revs and sounds almost like a diesel engine now. someone said to me it could be just a pulley bearing or something.
Anyone experienced this or know what it could be??
Offline rattleist
Re: SERIOUSLY WORRIED!! advice please
« Reply #1 on: 08 August 2010, 23:01 »
sounds more like a piston or one the ends hav gone!
Offline A8vgti
« Reply #2 on: 08 August 2010, 23:10 »
Is it down on power? If it is the top end. Possibles could be dropped valve, snapped a cam shaft. Maybe a failed hydrolic lifter? Fair amount of possible causes but doesnt sound good and wouldnt run it incase of causing more damage.
« Reply #3 on: 08 August 2010, 23:11 »
Knocking I would say suggests a bearing problem
Offline Dmonday
« Reply #4 on: 08 August 2010, 23:13 »
+1 - i got this sort of noise when my topmounts went :smiley:
Dan
Offline wrobstar21
« Reply #5 on: 08 August 2010, 23:15 »
not down on power at all, running as it should just sounds bad.
topmounts? where are those? in the head?
Offline wrobstar21
« Reply #6 on: 08 August 2010, 23:17 »
its not like a heavy knockin noise but still sounds bad!!!
« Reply #7 on: 08 August 2010, 23:17 »
Don't use it until you have got it sorted.
Offline Dmonday
« Reply #8 on: 08 August 2010, 23:22 »
Their on the top of your shocks, i found at different speeds & when i let off the gas it stopped knocking sometimes, and when turning. Replaced these and was fine untill i smashed them again :grin:
Dan
Offline wrobstar21
« Reply #9 on: 08 August 2010, 23:25 »
ah, i see. no this is defo from the engine.
Hope it aint to bad to fix, might get a recon head. anyone know where from though. cant find anywhere except g-werks for 395 squid
