Author Topic: help my tdi mk3....  (Read 983 times)
Offline broken-passat
  • tdi wagon .....
help my tdi mk3....
« on: 08 August 2010, 21:22 »
my golf suffers from poor starting hot or cold. just cranks and cranks... heres the BUT , it fires and runs with the startor motor? so once key released stalls or nearly stalls unless you apply full throttle . no fault codes or performance issues just poor starting. :sad:
i suspect either fuel pump timing or ignition switch fault . switch is fault anyway as have no radio signal wire or its intermitant.
could any oone shed any light on this ? or has any one got a wiring diagram of the 50 / 15 signal to the pump/ecu?
many thanks XX :kiss:
