Author Topic: ABF + G60 supercharger.  (Read 9915 times)
Offline danny_p
Re: ABF + G60 supercharger.
« Reply #10 on: 09 August 2010, 11:33 »
i would be very tempeted to look at the M90 from the jaguar  :wink:      nice big charger so you can get the airflow without the revs  it's all more efficent less stressed and won't whine half as much also there is the potential for a hell of a lot of air if you want it
all the VW's have gone bar 1.
Offline Skid
« Reply #11 on: 09 August 2010, 15:15 »
Wow - M90?????
'Tis a big old beast mostly used on 3.5 litre plus production engines, plus really quite a porker I think. Actually I wonder if it would even fit??
M45's were fitted to Mini Cooper and Mercedes of 1.8 to 2.3 litre I think. (not good on my Merc knowledge) The M64, (my choice) is a lot rarer than the M45 and was used mostly in the UK by Mercedes on I guess 2.8 to 3.2 litre engines.
Beware when sourcing one though as I ended up with a Merc Kompressor from a higher capacity engine and it turned out to be an M45(!!!!!) which I had to resell. Merc were very canny at sticking a Kompressor badge on a car, and totally underspeccing and gearing it so it only ran puff at low revs ( to help a multi valve engine have torque to pull a heavy car away) then at mid revs an actuator would disengage the charger and bypass the inlet. total token bollocks of a set up if you ask me. The drive wheels for the one I saw I think was 230mm (!!!!) this meant it got spinning up quickly at low crank pulley revs, then was disengaged at mid revs.
Anyway my M64 has been rebuilt and the cluth removed so it is permenantly on  :evil:
Offline clipperjay
« Reply #12 on: 09 August 2010, 15:20 »
They get quite hot twin screws  :wink:
« Reply #13 on: 09 August 2010, 16:12 »
Wow - M90?????
Beware when sourcing one though as I ended up with a Merc Kompressor from a higher capacity engine and it turned out to be an M45(!!!!!) which I had to resell. Merc were very canny at sticking a Kompressor badge on a car, and totally underspeccing and gearing it so it only ran puff at low revs ( to help a multi valve engine have torque to pull a heavy car away) then at mid revs an actuator would disengage the charger and bypass the inlet. total token nuts of a set up if you ask me. The drive wheels for the one I saw I think was 230mm (!!!!) this meant it got spinning up quickly at low crank pulley revs, then was disengaged at mid revs.
Anyway my M64 has been rebuilt and the cluth removed so it is permenantly onĀ  :evil:
They used M60 on some or most, M45 is 1.6 and below and will be no good for a ABF
« Last Edit: 09 August 2010, 16:14 by Wayne »
Offline twistedblack69
  • Proud mk2 user and abuser
« Reply #14 on: 09 August 2010, 17:39 »
use a fully worked over audi v8 head and forged bottom end with some really nice big barrel throttels you can get more than 240 NA
Can you fit a V8 in a mk2? I've never come across that conversion, will have to look into this  :evil: :evil:
Offline fishnchipsx2
« Reply #15 on: 09 August 2010, 18:14 »
Lol, he's talking about just using one of the V8 heads (imagine half a V8, well sort of)
« Reply #16 on: 09 August 2010, 20:25 »
Haha can you do that? Or is he having me on?
« Reply #17 on: 09 August 2010, 20:49 »
Not 100% sure, from memory the Audi V8 was 2 ABF heads on a common block.
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #18 on: 09 August 2010, 23:48 »
indeed, eatons are about the only charger to have an adiabatic efficiency worse than a g60  :lipsrsealed:
Offline danny_p
« Reply #19 on: 10 August 2010, 01:49 »
the some of the audi V8 heads offer more potential than the std ABF head.
