Author Topic: caliper clearence with 13's  (Read 2070 times)
Offline celyth
« on: 08 August 2010, 16:28 »
hey all,
got a mk2 rocco gtx that ive been running for a while with 13x8 allycats on, the problem is i have to use a 6mm spacer on the front and have also ground a lot of the caliper off to get them to clear, ive decided thats its not safe enough with how much ive ground off so i wanna find out if theres smaller calipers i can fit that the allycats would then clear, preferably without spacers too as they stick out loads, ive tried them on a mk1 1.3 golf but they still catch on them too,
any info would be great
cheers
cel
Re: caliper clearence with 13's
« Reply #1 on: 16 August 2010, 13:43 »
is it the caliper or the carrier its hitting? the  later mk1 carriers have a big hoop of metasl which pokes out past the caliper and can cause clearance issues. if this is what you are having problems with, fit earlier MK1 1.5-1.8 carriers as they dont have that metal hoop :)
your old calipers will bolt right up to them so no need to undo flexi lines or anything
Offline celyth
« Reply #2 on: 16 August 2010, 20:13 »
ahh yeah thats the one, bloody thing, ive got a Y reg 1.3 mk1 golf here but thats got the same carrier on it :S do you mean a mk1 golf or rocco?
« Reply #4 on: 17 August 2010, 10:08 »
no its the carriers you need to change, not the calipers.
these are the late carriers, note the hoop round the front:
heres a pic side by side showing the late and early carriers, note early ones on the right have no hoop and more wheel clearance:
The same caliper is used on both carriers :)
edit: you may be able to cut the front of the hoop off, but i wouldn't risk it just get some early carriers and bolt em on.
Offline celyth
« Reply #5 on: 17 August 2010, 20:34 »
ok cool, cheers m8, not much left on mine as it is coz ive grined loads off :S dont wanna risk cutting them off tho, will see if anyone has any on here :)
thanks for the help, much appreciated :)
