Author Topic: Disconneting The Airbag  (Read 1703 times)
Offline zdebx
« on: 07 August 2010, 21:23 »
How do you disconnect the bloddy thing from the plug?
You have to remove the indicator stalk, right? I removed all 3 flat-head screws, but still couldn't take out the stalk...
What's the magic?
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
Offline adi
Re: Disconneting The Airbag
« Reply #1 on: 07 August 2010, 22:19 »
do you just remove the steering wheel, and swap to standard?
Offline zdebx
« Reply #2 on: 07 August 2010, 22:33 »
Yes, mate. Couldn't disconnect the airbag wire from the plug to remove the steering wheel.
I can't figure out how to remove that indicator stalk.
Offline adi
« Reply #3 on: 07 August 2010, 22:43 »
dose it not just unplug from the back of the airbag itself. there are 2 torx holding the airbag to the steering wheel i just removed this and unpluged it from the airbag itself.
Offline zdebx
« Reply #4 on: 07 August 2010, 22:47 »
I've done that and removed the airbag, but I need to unplug the wire, which is attached to the steering wheel, otherwise I can't remove it completely, even after undoing the 24mm nut.
The bit that I'm confused about is how to remove the bloddy stalks.
Offline adi
« Reply #5 on: 07 August 2010, 23:00 »
i think you just remove the two screws at the top near the hazard switch and just pull it off.http://www.edition38.com/forums/index.php?showtopic=174698 just found this link dont know wether it will help.
Offline zdebx
« Reply #6 on: 07 August 2010, 23:16 »
Thank you SO MUCH for the link, mate.
That's exactly what I needed. I didn't know there are 2 more screws underneath...I was wondering why the fcuk it wasn't coming off, lol
Will try it tomorrow.
