Author Topic: Wheel Bearing Torque Settings  (Read 2861 times)
Offline Chew22
« on: 06 August 2010, 13:15 »
Hey guys, I thought I had a worn out rear wheel bearing (when it was actually the front) so I removed the hub and the nut with the split pin. I did it back up quite tight, but it wasn't tight when I took it off. How is it meant to be?
Is there any Torque settings for it?
Thanks,
Josh
Re: Wheel Bearing Torque Settings
« Reply #1 on: 06 August 2010, 13:40 »
Tighten to you have no play, if you overtighten it you will crush the bearing.
Offline oldynewby
« Reply #2 on: 08 August 2010, 22:18 »
The wheel bearings should be torqued up to 15lbs/sq in to seat the bearing then undone and done up finger tight so that you just eliminate the play. Don't do them up tight or the bearing won't last 5 minutes!
1994 Mk3 Golf GL 1.8. Dusty Mauve. Currently pranged and awaiting parts for MOT.
2005 Suzuki GSF1200S Bandit. Silver. Currently stepping into the breach.
Offline Chew22
« Reply #3 on: 09 August 2010, 09:23 »
Thanks for the advice guys. I took it to the garage after work, as he did loosen it up, but no damage was done. Phew!
