Author Topic: BUZZED OUT ON TIMING VR6  (Read 1114 times)
Offline seamud
« on: 05 August 2010, 00:28 »
iv timed up tdc by markings on transmission side can see marking on block but not on pully used screw driver in cylinder 1 to confurm tdc and cams line fat side facing down  my rotor arm faces down by plug for hall sensor which is 180 degrees out from where cylinder1 ht lead goes and car wont fire am i missing something out
Offline sharki786
  • GOT BOOST??
Re: BUZZED OUT ON TIMING VR6
« Reply #1 on: 07 August 2010, 12:39 »
bent valves? i hope its not bent valves as it will cost alot to sort out. can you smell fuel?
*****MK3 Anniversary*****
*****MK4 GTI T*****
