Author Topic: DSG and the footbrake light  (Read 2616 times)
Offline Ant
« on: 04 August 2010, 19:06 »
Whenever I come to a halt and shift in to neutral the footbrake light comes on, requiring the footbrake to be pressed to shift back into drive (wasn't that what the button on the gear lever should have been for).
Is there anyway to turn this stupid thing off, can it be done with VagCom?
Offline weston
Re: DSG and the footbrake light
« Reply #1 on: 04 August 2010, 20:58 »
I thought the button was for going in and out of reverse. The footbrake just has to be pressed to engage the gearbox, presumably a safety feature. Is it that much of an issue?
Offline Mortimer Hill
« Reply #2 on: 04 August 2010, 21:32 »
Legally, the DSG models are classed as automatics,  and I believe the legislation on cars with an automatic transmission requires there to be an interlock so that the brake pedal must be depressed when moving from neutral into drive or reverse, or park into reverse. I believe this arose from people putting cars into drive or reverse and the car "taking off" and the drivers then panicking and pressing the accelerator rather than the brake, exacerbating the problem.
The button on the DSG shift lever is to control selection of S mode.
Offline weston
« Reply #3 on: 04 August 2010, 21:37 »
And reverse
« Reply #4 on: 05 August 2010, 00:10 »
Yep, spot on blame the yanks and Audi.
Offline Ant
« Reply #5 on: 05 August 2010, 01:06 »
My Dad's car is an automatic around the same year and only requires foot brake to come out of parking.
On older automatics (iirc) it was always the button that was required to shift the lever from N to D.
Why having a button to go from D to S but allow you to go from D to N without it is beyond me.
I just find it annoying when stopped at lights I either have to stand on the brakes or put it in neutral and then hit the brakes before I move off.
I'm sure though that when I was test driving Mk5's I didn't have to do this on all cars, which is why I wondered if it could be turned off, they were probably just earlier models.
