Author Topic: brake conversion  (Read 1541 times)
Offline colourcongti
brake conversion
« on: 10 January 2005, 16:32 »
Right i have the chance of getting a 1.6 driver i am looking at doing a vr6 upgrade on it i just want to know how easy is it to replace the rear drums with disks and what disks are good to replace with cheers
Offline Dizzie
  • Make friends with your fast
Re: brake conversion
« Reply #1 on: 10 January 2005, 16:35 »
put the gti discs on the back and the 288mm VR6 ones on the front uprating the master cylinder to a 23mm one also.
VeeDubGTI16v
« Reply #2 on: 10 January 2005, 16:48 »
you need 16's for vr6 brakes i think :huh:
Offline Gambit
« Reply #3 on: 10 January 2005, 17:43 »
just go for a g60 setup with braided lines. thats more than ample stopping power
« Reply #4 on: 10 January 2005, 19:15 »
how easy is it to do this
Offline ...joe
« Reply #5 on: 10 January 2005, 19:53 »
depends how good you are at spanner weilding! just a thought though....is it not easier to use a gti as a base model as i swear there alot of other bits that you'd have to change on a driver that you could get away with on a gti? in relation to wiring, fuel etc? i may be wrong? but brakes are pretty easy.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
« Reply #6 on: 12 January 2005, 13:19 »
Best bet is to get hold of an entire GTI rear beam, that way you'll get the internal ARB with it.? Then you just need std GTI handbrake cables?and possibly brake lines cant remember :smiley:
« Last Edit: 12 January 2005, 13:21 by rubjonny »
