Author Topic: Oil Pressure Warning light & stupid buzzer  (Read 5033 times)
Offline tigerj360
Re: Oil Pressure Warning light & stupid buzzer
« Reply #10 on: 04 August 2010, 15:17 »
they did check it through a pressure gauge and said it was creeping into low once the engine was fully warmed up but they said it wasn't enough to cause any harm, so im not sure weather the new oil pump will make the difference
Offline Horney
« Reply #11 on: 04 August 2010, 15:20 »
If that's the case then you maybe OK but if it's low enough to set the buzzer off that's really not good. My MKII is currently off the road as it's dropping pressure when hot and I dare not use it.
A new pump may help as the pick up could be blocked, this has happened to me and a new pump (or cleaning the gauze on the old one) fixed it. This time I'm not sure what my problem is as I haven't dropped the sump off yet.
Nick
Offline tigerj360
« Reply #12 on: 04 August 2010, 15:26 »
yeah hopefully everythings fine and the new oil pump will restore it to a good pressure, even once its warmed up. I suspected it was the oil switch at first but even after changing that and a oil, oil filter change it was going off so new oil pump will probably be a good call, im going to take it into the garage tomorrow and get them to check pressure make sure its still ok to drive on just to make sure.
back on topic though any ideas on how to get rid of the beeper?  :grin:
hope the MKII gets better though  :smiley:
Jon
Offline Horney
« Reply #13 on: 04 August 2010, 15:29 »
Taking the wires off the senders and wrapping them in electrical tape should sort it out.
Nick
« Reply #14 on: 04 August 2010, 15:29 »
Why remove the beeper, it is telling you that you have a problem.
It may save your engine in the future.
Also if you have oil pressure dropping when hot do not drive it, you have been lucky up to now but you run the risk of damage if you carry on using it.
Offline tigerj360
« Reply #15 on: 04 August 2010, 15:32 »
ok cheers guys
your both right i can live without the car for a bit instead of forever.
she is my pride and joy after all  :nerd:
Jon
P.S what/where are senders sorry for the nooby questions
Offline Horney
« Reply #16 on: 04 August 2010, 15:36 »
There will be a couple of sensors (it's a GTI right?) that set off the buzzer when the pressure drops below a certain level. If you pull the connectors off them and tape them up they wont read the pressure drop and set the buzzer off. Would really need you car spec and engine code to confirm where they are on your car though.
Nick
Offline tigerj360
« Reply #17 on: 04 August 2010, 15:39 »
Nick
Nah sorry its a 95 MKIII 1.6 CL i know where the oil pressure wires are (inbetween left spark plugs) so i would just take it off an cover in electrical tape? because iv tried taking it off without the tape and it just buzzes allll the time ha
Offline MotorPsycho
  • I drive a 2000bhp dragster, so what ;)
« Reply #18 on: 04 August 2010, 15:43 »
oh I thought this was the funny quotes thread on edition when I read the first post........
1983 mk1, 2.0, TSR pack C head, Eaton M45 - work in progress
1990 mk2 GTD, boost, fuel, soot
16v GTi mk3; chilli red, 16" Audi Speedlines, coilies
1934 Ford Dragster, 200mph in 6 seconds.
Offline AudiA8Quattro
« Reply #19 on: 04 August 2010, 15:49 »
I can't believe what's in this thread.
If the oil pressure is low, do NOT drive the car.
You don't know if damage is being done, once the engine starts knocking it will be too late.
It might not even be a knackered oil pump, remove the sump and check the oil strainer, it may be partially blocked.
