Author Topic: Brakes  (Read 1264 times)
Offline benji mk2
  • Soon be christmas!
Brakes
« on: 10 January 2005, 15:39 »
Tried to fit my nice new 16v servo and master cylinder this weekend, however things did not go to plan :cry:  Firstly the clevis at the back of the servo wont fit onto the small ball joint (this could probably be made to fit with a bit of subtle modification) . The second problem is that on the old clevis there is a small hole for a little return type spring to sit in, on the 16v unit  this isn't there and it doesn't look like there is room to drill one? This has got me stuck, anyone got any ideas????????
Offline gibby
Re: Brakes
« Reply #1 on: 10 January 2005, 16:05 »
Don't know about your problem but is there anything in this sticky thread in this section that might point you in the right direction http://www.golfgtiforum.co.uk/index.php?topic=8181.0  :undecided:
......now officially dubless.
Offline benji mk2
Re: Brakes
« Reply #2 on: 10 January 2005, 20:25 »
Cheers for the reply Gibby!
 Unfortunately there isnt much about servo's in the thread.
  Anyone else got any ideas?????
Offline mk1
Re: Brakes
« Reply #3 on: 10 January 2005, 21:18 »
I unscrewed the clevis off the mk1 servo and fitted it to the bigger one, I used a passat servo so yours may be different.
Steve.
Offline benji mk2
Re: Brakes
« Reply #4 on: 11 January 2005, 08:46 »
Cheers Steve, do you know if that part is still available as i broke mine trying to do them same?  Isn't it allways the way, the really easy jobs turn into a bloody nightmare!! :evil:
Offline mk1
Re: Brakes
« Reply #5 on: 11 January 2005, 19:13 »
I think you should be able to get one, poss from a rocco.
Steve.
