Author Topic: can i Paint inlet manifold?  (Read 1955 times)
Offline DubSociety
Re: can i Paint inlet manifold?
« Reply #10 on: 04 August 2010, 17:34 »
How do you go about painting it without removing anything ??? ... im talking about on the 16v ... is their any sort of heat proof hammerite paint in halfords for example that can be picked up to be put on carefully using a paintbrush? because at the moment, my valver underneath the hood is let down by the crappy discoloured engine, wouldnt mind just carefully painting it black, and having the DOHC in red.
Credit to: Len for his engine bay piccie :)
« Last Edit: 04 August 2010, 17:41 by DubSociety »
Offline Baskey
« Reply #11 on: 04 August 2010, 17:40 »
There are loads of heat proof paints you can use. Hammerite heatproof worked well on my motorbike exhaust. As for the vr6 inlet I think the look tacky painted. I would take it off and spend an evening cleaning it right up with metal cleaners
Offline DubSociety
« Reply #12 on: 04 August 2010, 17:42 »
Oh right, so their is infact an actual hammerite heatproof paint lol? fair enough.
Offline rattleist
« Reply #13 on: 04 August 2010, 17:50 »
Hammerite paint is just heatproof, it is in halfords yes, just get a tin and you can paint straight on, its good on calipers aswel, its really thick and you dont need primer either, i just dint know weather it was OK on inlets, i was having a hung over moment thou and i couldn't think straight lol
Offline Baskey
« Reply #14 on: 04 August 2010, 17:53 »
Yes bud hammerite do a heatproof paint but any brand will be fine
Offline rattleist
« Reply #15 on: 04 August 2010, 18:02 »
Go to halfords online, you will find the paint on there, its also in bnq, homebase, the range, most stores like that mate! I think im going to do what wayne said and take it off and spray my bits for a smoother finish
