On top of that I got a stone chip today about 1/4 inch in diameter. Its taken all the paint off and exposed clean metal underneath. This happened less than 2 weeks after I polished and waxed the car all over with a Megs G22. The car was pristine. So I am annoyed. Going to try to get a Tornado Red touch up pen and fix it.
I hada similar thing happen before I'd even got mine home from the dealer after collecting it!
I collected a stone on the complex curve on the wing near the corner of the drivers headlamp, enough to dent the wing - really obvious.
I had the Dent Master bloke work his magic, on the dent - 20 mins later he had the dent out.
A layer of VW Tornado Red paint later and it was looking better - touch-up dropped in a cup of freshly boiled water (to thin it) and allowed to run into the chip along a piece of cleaned thin solder.
I filled the paint layers up with the lacquer using a similar method, once the Red had dried fully (overnight) and once dried, spot wet-sanded it back level using my G220 and used the G220 again to polish the wing up.
If you look close you can see it...but it's 99% better than it was.
VWs Tornado Red touch up is pretty close colour wise, but you will need the clear on top to give it the gloss and lighten the Red slightly.
You should be good to go, as long as the galvanising isn't affected.
